SMAC致动器用于燃料杆量测
Sure Tool -SMAC Gauging (SMAC量测) By Steve Curtiss
MLAS55-500-8 (X轴), LAS95-50-7(Y轴), LAL35-50-7,(Z轴),MAAC4-7 (4轴控制器)
Fuel Rail Gauging Using SMAC Actuators 使用SMAC致动器进行燃料杆量测
A fuel rail made for GM needed to be 100% checked by the supplier before GM would accept the product. The dimensions of a fuel rail are very critical. If there is a problem a fuel leak will happen, as the latest fuel injections systems operate at 3,500 psi, this is much higher pressure than used in previous fuel rails. To demonstrate how critical the dimensions are at one point a rail was shipped with a human hair on one of the cups that caused a bad fuel leak in the final assembly. Now all employees must wear hair nets. This is a very clean manufacturing environment. The fit & location of all of the points inspected are critical on this high pressure fuel rail.
用于通用(GM)的燃料杆需要百分百的被检测.燃料杆的尺寸被要求的相当严格.若是不准确,就会有漏燃料的情况发生.由于最近燃料喷射系统操作在3,500psi,
SMAC音圈电机用于玻璃切割或划线设备
SMAC音圈电机在手机制造机械化检测系统的应用
LCA25系列音圈电机
SMAC LCA25系列音圈电机
SMAC音圈电机在智能卡生产上的应用
