上海史脉可电机-升级后LAR31线性及旋转电机
SMAC Moving Coil Actuators (SMAC移动式线圈致动器)
The vacuum-though shaft eliminates common dust problems in pick and place applications. Upgraded LAR31 series of linear and rotary actuator improves performance and reliability in PCB assembly.
轴端设有真空功能可排除取放运动中常见的灰尘问题. 升级的LAR31系列的线性旋转致动器改善了PCB组装的运动.
SMAC为您介绍升级的LAR31系列线性以及旋转的电动致动器.致动器旋转马达轴端内建真空管.真空管可以确保外部的物体(例如:灰尘)等排出避免灰尘进入致动器.因此可以改善生产线的效率.LAR31产品可信赖且已经测试MTBF超过1亿次的寿命循环
The SMAC LAR31 series electric linear and rotary actuator is equipped with a standard encoder resolution of 5µm, with options of 1µm, 0.5µm and 0.1µm resolutions. Repeatable positioning to +/- 2 encoder counts. Further to this highly accurate placement with shaft run-out ≤ 10um. The unit has no backlash, low repeatable friction and very low hysteresis. The LAR31 series actuator is compact measuring only 140mm x 77.25mm x 35mm with stroke length 30mm, and 180mm x 77.25mm x 35mm with stroke length 50mm. The actuator can easily be programmed to control force/torque, position & velocity in all axes at the same time. This enables the ability to press with specific force and measure displacement.
SMAC的LAR31系列的致动器为线性旋转致动器,标准的分辨率为5um另外有1µm, 0.5µm and 0.1µm供选择. 重复定点达+/- 2编码读数. 提交
SMAC音圈电机用于玻璃切割或划线设备
SMAC音圈电机在手机制造机械化检测系统的应用
SMAC致动器用于燃料杆量测
LCA25系列音圈电机
SMAC LCA25系列音圈电机
