The GTS370 is a robust lunchbox computer built using heavy duty metal to provide tough, go-anywhere unit ideally suitable for surround system and video applications. Every GTS370 comes equipped with three high resolution LCD displays, dual system cooling side fans and easy access to its expansion ports for immediate system upgrade or maintenance. Functional practicality combined with the simple and polished design, the GTS370 with its extra-rugged construction to sustain bumps and impacted blows is the most cost-effective, durable and efficient portable solution for your needs.
Instant Setup:
Setting up is no hassle. GTS370 enables you to be up-and-running in seconds without complicated setup. Our all-in-one design has integrated keyboard, mouse, and display into a total package for your convenience.
LCD Display Information:
The GTS370 has built-in three high resolution LCD screens. With our engineering advancement, LCDs can be expanded and retracted fully effortlessly.
The GTS370 is integrated with high brightness, high contrast and fast response LCD screens.
