山东莱恩科技安全光幕安全等级
2016/4/6 14:27:51
Safety Light Curtains (Type 2)
Type 2 safety light curtains are a low-cost solution for guarding lower-risk applications,
where the result of an accident is only a slight injury.
Safety Light Curtains (Type 4)
Safety light curtains protect personnel from injury and machines from damage by guarding
points of operation, access, areas and perimeters.
二级安全光栅
1.成本低;
2.性能:单CPU处理器;
3.双安全通道输出;
4.可以自诊断或外部周期测试进行故障检查;
5.故障排除法来保证安全性能;
6.应用在伤害程度中等或者较小的场合和机器上
四级安全光栅
1.成本较高;
2.性能:双cpu处理器;
3.双安全通道输出;
4.控制更可靠,受干扰光影响略小一些;
5.自我诊断进行故障检查,更高级别冗余故障互检等;
6.应用在伤害程度较重的高危险场合或者机器上,提供危险区域保护
莱恩 SR4P2A1B24C安全继电器
莱恩SLDR-1000系列安全激光扫描仪
莱恩SFC系列安全光幕
避障激光雷达,激光扫描仪
反射式,漫反射式光电开关
