steute HS Si 4 安全传感器
安全传感器
产品分类:功能安全 设备安全 安全控制产品
品牌:世德
· Thermoplastic enclosure
· Long life
· High shock resistance
· Hall sensor 1 NC/1 NO or 2 NC contacts
· Galvanically separated channels
· With pre-wired cable
Technical data
Standards |
EN ISO 13849-1; |
Enclosure |
glass-fibre reinforced thermoplastic, |
Defined object |
Actuator MC 4 |
Degree of protection |
IP 67 to IEC/EN 60529 |
Switching system |
Hall sensor, 2 channels galvanically separated, semiconductor |
Connection |
cable, 6 x AWG 26 |
Safety-relevant data: |
EN 954-1 |
Category 4 * |
EN ISO 13849-1 |
PL e |
TM |
max. 20 years |
MTTFd |
> 100 years |
Utilisation category |
DC-13, DC-12 |
Ie/Ue |
40 mA / 24 VDC |
Ue |
10 … 30 VDC |
Ui |
75 VDC |
Uimp |
1 kV |
Residual current |
≤ 6 mA per channel |
Voltage drop |
≤ 2.5 VDC |
Switch-on/switch-off time |
< 1 ms |
Risk time |
< 100 ms |
Max. fuse rating |
< 50 mA internal reversible fuse |
Switching frequency |
max. 1000 Hz |
Degree of pollution |
3 |
Overvoltage category |
II |
Ambient temperature |
-20 °C … +70 °C |
Switching capacity: |
sao |
6 mm |
sar |
20 mm |
steute参加上海2012工业自动化展
steute STM 295 磁锁开关
steute ST 14 安全门锁开关
steute ES 95 AZ 安全门锁开关
steute ST 61 安全门锁开关
