steute ST 61 安全门锁开关
安全门锁开关
产品分类:功能安全 设备安全 安全控制产品
品牌:世德
· Metal enclosure
· Double insulated
· Slow action, change-over contact with double break
· 3 cable entries M20 x 1.5
· Wiring compartment
· Long life
· High level of contact reliability with low voltages and currents
· Gold-plated contacts available on request
· Ex version available
Technical data
Standards |
EN ISO 13849-1; |
Enclosure |
aluminium die cast, paint finish |
Actuator |
stainless steel 1.4301 |
Degree of protection |
IP 65 to IEC/EN 60529 |
Contact material |
silver |
Switching system |
slow action, positive break NC contact |
Switching elements |
change-over contact with double break Zb or 2 NC contacts, galvanically separated contact bridges |
Connection |
plug-in connector |
Cable section |
max. 2.5 mm² |
Cable entry |
3 x M20 x 1.5 |
B10d (10 % Load) |
2 million |
TM |
max. 20 years |
Uimp |
6 kV |
Ie/Ue |
ST 61 1NC/1NO: 16 A/400 VAC |
Mechanical life |
> 1 million operations |
Utilisation category |
AC-15 |
Max. fuse rating |
ST 61 1NC/1NO: 16 A gL/gG D-fuse |
Positive break travel |
10 mm |
Ambient temperature |
–20 °C … +80 °C |
Mechanical life |
steute参加上海2012工业自动化展
steute STM 295 磁锁开关
steute ST 14 安全门锁开关
steute ES 95 AZ 安全门锁开关
steute BZ 16 安全传感器
