steute ES 95 AZ 安全门锁开关
安全门锁开关
产品分类:功能安全
品牌:世德
· Thermoplastic enclosure
· Double insulated
· Slow action, change-over contact with double break
· Wiring compartment
· Design according to EN 50047
· Horizontally slotted mounting holes
· Actuator can be repositioned in factory by 4 x 90°
· With connector M12 x 1.5, 4-pole available on request
· Gold-plated contacts available on request
· Ex version available
Technical data
Standards |
EN ISO 13849-1; |
Enclosure |
glass-fibre reinforced, shock-proof thermoplastic, self-extinguishing UL 94-V0 |
Actuator |
stainless steel 1.4301 |
Degree of protection |
IP 67 to IEC/EN 60529 |
Contact material |
silver |
Switching system |
slow action, positive break NC contact |
Switching elements |
change-over contact with double break Zb or 2 NC contacts, galvanically separated contact bridges |
Connection |
M3 screw terminals |
Cable section |
max. 1.5 mm² |
Cable entry |
1 x M20 x 1.5 |
B10d (10 % Load) |
2 million |
TM |
max. 20 years |
Uimp |
4 kV |
Ui |
250 V |
Ithe |
6 A |
Ie/Ue |
6 A/400 VAC |
Utilisation category |
AC-15, DC-13 |
Max. fuse rating |
6 A gL/gG D-fuse |
Positive break travel |
9 mm |
Ambient temperature |
–20 °C … +80 °C |
Mechanical life |
> 1 million operations |
steute参加上海2012工业自动化展
steute STM 295 磁锁开关
steute ST 14 安全门锁开关
steute ST 61 安全门锁开关
steute BZ 16 安全传感器
