产品选型
steute BZ 16 安全传感器
steute BZ 16 安全传感器
安全传感器
产品分类:
功能安全 设备安全 安全控制产品
品牌:
世德
 Features/Options
·         Thermoplastic enclosure
·         Long life
·         Differential inputs: Induction/Hall sensor operating principle
·         Internal monitoring, high manipulation protection
·         Potential-free outputs
·         1 NC/1 NO contact or 2 NC contacts
·         Available with 3 different actuating planes:
   actuating from the top "D",
   actuating from the bottom "U",
   actuating from the front "V".
   Please indicate the desired actuating plane when ordering.
·         Switching capacity sao 10 mm, sar 20 mm
·         Wiring compartment
·         Version with higher degree of protection IP 69K available
Technical data
Standards
EN 61000-6-1, -2, -3, -4;
EN 60947-5-2;
EN 60947-5-3/PDF-M*; EN 954-1;
EN 1088; EN ISO 13849-1;
DIN EN 62061; 2004/108/EG
Enclosure
glass-fibre reinforced thermoplastic, self-extinguishing
Defined object
actuator BZ 16-B1
(order no. 90570007)
non-flush mounting
Limit distances
switch-on distance sao = 10 mm,
switch-off distance sar = 20 mm
(When no ferromagnetic material is present in the vicinity of the sensor or actuator. Minimum distance 2 mm for approach from side.)
Hysteresis
approx. 6 mm
Sideways tolerance
≤ 3 mm
Repeatability
< 1 mm
Safety-relevant data:
EN 954-1
Category 4 *
EN ISO 13849-1
PL e
TM
max. 20 years
MTTFd
57.8 years
DIN EN 62061
SIL CL 3
PFHD
≥ 3 x 10-8
Ie/Ue
160 mA/24 VDC ± 15 %
(reverse voltage protected)
Residual current
< ≤ 70 m> mA
Max. fuse rating Ue
0.25 A (slow blow)
Output contacts
2 enabling paths
(2 NC or 1 NO/1 NC)
Switching voltage
max. 250 VAC
Cond. short-circuit current
100 A
Voltage drop
refer to contact resistance
Max. fuse rating
4 A (gL/gG) incoming series-connected
Utilisation category
AC-15; DC-13
Ie/Ue of output contacts
3 A/230 VAC; 4 A/24 VDC
Ui
250 VAC
Overvoltage category
III
Degree of pollution
3
Uimp
4 kV
Max. switching frequency
1 Hz
Risk time
< 200 ms
Degree of protection
IP 67 to IEC/EN 60529
Ambient temperature
0 °C … + 55 °C
Mechanical life
50 mio. operations
Contacts
AgSnO self-cleaning, positive-guided
Contact resistance
100 mΩ in new condition
Connection
cable entry M20 x 1.5, terminal space with self-lifting clamps for max. 2 x 1.5 mm² (incl. conductor ferrules)
steute参加上海2012工业自动化展
steute STM 295 磁锁开关
steute ST 14 安全门锁开关
steute ES 95 AZ 安全门锁开关
steute ST 61 安全门锁开关
