TOPSSD T9050 series Industrial Compact Flash cards are embedded solid-state data storage systems for mobile computing and the industrial work place. Using SLC NAND FLASH technologies to effectively boost product stability and performance for general and professional applications.The Industrial grade CompactFlash features an extremely lightweight, reliable, low-profile form factor. It support advanced PIO (0-6), Ultra DMA (0-7) transfer mode, multi-sector transfers, and LBA addressing. In addition , it's shock proof and low power consumption SSD characteristics makes it the ideal choice as a storage solution.
天硕 T9050高速工业CF卡嵌入了固态数据存储系统,适用于移动计算和工业工作场所。采用SLC NAND闪存技术,无论是一般或专业应用,都能有效地提高产品的性能和稳定性。工业级闪存的特点是有一个非常轻便、可靠、低调的外形。它支持先进的PIO(0-6),Ultra DMA(0-7)传输模式和LBA寻址。此外,它的耐冲击、低功耗的SSD的特性使得选择它成为了一个理想的存储解决方案。
基本描述 | |
型 号 | T9050CF16GB |
容 量 | 16GB |
闪存类型 | SLC NAND Flash |
读写速度 | Read: 110MB/s, Write: 100MB/s |
接 口 | Compact Flash Type I, CF 5.0, ATA/ATAPI-5 compatible |
传输模式 | PIO Mode:0-6, Multi word DMA Mode: 0-4, Ultra DMA Mode: 0-7 |
可靠性 | |
校验修正 | Embedded advanced hardware ECC engine |
损耗控制 | Global wear-leveling to extend the product life cycle |
MTBF | >3 million hours |
插拔寿命 | Testing Condition: 3sec/cycle – Repeated Plug/Unplug 10,000 cycles |
工作环境 | |
工作温度 | -20℃~ +70℃ |
存储温度 | -55℃~ +125℃ |
湿 度 | 10-95% Relative Humidity (Non-dewfall) |
抗 冲 击 | 1500G@0.5ms |
抗 振 动 | Sine (Non-op) : 20Grms,7~2000Hz / Random Vibration(op) : 6Grms, 10~500Hz |
电源需求 | |
输入电压 | DC +3.3V ± 5% or DC +5.0V ± 10% |
电源模式 | Auto Stand-by and Sleep Mode |
功 耗 | <105mA in operation |
规格与保修 | |
外形尺寸 | 42.8mm x 36.4mm x 3.3mm |
重 量 | <12g |
保修期限 | 5 years |
- 我要试用产品
- 我要产品资料
- 我要技术支持
- 我要咨询采购
