信步第6/7代高性能Core平台核心模块SCM-DH113
2021/5/27 11:48:21
SCM-D核心模块, Intel 6/7代Core i3/i5/i7处理器, H110芯片, DDR4内存, 2*Intel GbE
产品分类:嵌入式系统 物联网 嵌入式主板 应用层
品牌:信步科技
SCM-D (Seavo Compute Module) 核心模块
可选H110/ Q170芯片, 支持6/7代Core i3/i5/i7处理器
支持DDR4内存, 提供2*Intel千兆网卡
通过B2B连接器提供丰富的I/O与显示资源
载板可快速定制, 灵活选配SCM模块
146*105mm
规格:
General | |
CPU | Intel® 6/7th Generation Core™ i3/i5/i7, Pentium®, Celeron® CPU,LGA1151 Max TDP 65W,Quad-core |
Chipset | Intel® H110/ Q170, TDP 6W |
Memory | DDR4-1866/2133, 2*SO-DIMM, up to 32 GB |
BIOS | AMI UEFI BIOS |
System | Windows 7/8.1/10, Linux |
I/O | |
Ethernet | 2*Intel® 1Gbps PCIe Ethernet Controller |
Audio | 1*Realtek® ALC662 5.1 channel HDA Codec |
High Speed Signal | 4*USB3.0, 4*SATA 3.0, 1*PCIe x16, 3*PCIe When Chipset is Q170: 4*USB3.0, 4*SATA 3.0, 1*PCIe x16, 1*PCIe x4, 2*PCIe 2*HSIOA (USB 3.0/ PCIe), 2*HSIOB (SATA/ PCIe) |
USB 2.0 | 8*USB 2.0 |
Serial | 6*TTL |
GPIO | 4*programmable GPIO |
Feature Interface | 1*LPC, 1*SM BUS, 1*I2C, 1*SPI, 2*USB OC, 1*FAN Control, 1*Power Control, Power OK |
Display | |
Display Interface | 1*eDP, 1*VGA, 2*DDI DDI can be set to DP/HDMI/DVI |
Multiple Display | H110-Dual, Q170-Triple |
Mechanical & Environment | |
Dimension | 146*105mm |
Power Input | DC 12V, 5V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
信步自动化核心模块载板SV-B9689
信步机器人控制器核心模块载板SV-B1000
信步新一代高可靠工业计算机NAV-700
“一花独放不是春,百花齐放春满园” —— 信步科技展会侧记
把机器变成人,2023 信步开门红!
