产品选型
信步Tiger Lake平台智能网关主板NSE SVX-13554
Intel Tiger Lake系列处理器, 5*LAN, 3*M.2
产品分类:
嵌入式系统 物联网 嵌入式主板 应用层
品牌:
信步科技
采用Intel Tiger Lake Core i3/i5/i7, Celeron处理器
提供5个千兆网口, 4*USB 3.0, 2*COM, 1*HDMI, 1*LVDS/eDP
采用Intel IEM模块化规范设计,可灵活搭配I/O扩展模块
提供3*M.2, 支持 PCIe x4 NVMe SSD, 4G/5G, WIFI+BT
规格:
General
CPU
Intel® Tiger Lake 11th Gen Core™ i3/i5/i7, Celeron CPU
Memory
Support DDR4 3200 MHz, 2*SO-DIMM Slot, up to 64GB
Storage
1*M.2 (NGFF) Key-M Slot (PCIe x4 Gen4NVMe SSD, 2242/2280)
1*SATA 3.0
Expansion Interface
1*M.2 (NGFF) Key-B Slot (PCIe + USB, Support 4G/5G, 3042/3052)
1*M.2 (NGFF) Key-E Slot (PCIe + USB, Support WIFI+BT, 2230)
1*EIO Connector, for I/O Expansion, e.g. 2*GbE LAN, 4*COM, 1*HDMI, 2*DP
BIOS
AMI UEFI BIOS
System
Windows 10 64-bit, Linux
I/O Interface
Ethernet
5*Realtek GBE LAN, 10/100/1000 Mbps, RJ45
Serial
2*RS232/485 (COM1/2, Full lanes, DB9/M/ Header)
2*RS232 (COM3/4, 2 lanes, Header)
USB
4*USB3.0 (TYPE-A, Rear I/O)
2*USB2.0 (Header, Internal)
Audio
Realtek ALC662 5.1 Channel HDA Codec
1*Line-Out + MIC 2in1 3.5mm Jack
2*Amplifier, 5-W (per channel) into an 8-Ω Loads
Display
Display Interface
1*HDMI: max resolution up to 4096*2160@24Hz
1*LVDS/eDP: LVDS maxresolution up to 1920*1200@60Hz (default)
                    or eDP max resolution up to 4096*2304@60Hz
Multiple Display
Dual
Mechanical & Environment
Dimension
185mm*135mm
Power Input
DC 24V
1*ATX 4P Power InputRight Angle Connector
1*DC 24V Power Input Φ2.5mm Jack
TemperatureOperation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity
Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步自动化核心模块载板SV-B9689
信步机器人控制器核心模块载板SV-B1000
信步新一代高可靠工业计算机NAV-700
“一花独放不是春,百花齐放春满园” —— 信步科技展会侧记
把机器变成人,2023 信步开门红!
