信步Elkhart Lake平台智能网关主板NSE SVX-EHL262
2021/5/27 12:27:16
Intel Elkhart Lake系列处理器, 2*SFP, 6*LAN, 2组3代Bypass, 1*PCIe x8, TPM
产品分类:嵌入式系统 物联网 嵌入式主板 应用层
品牌:信步科技
采用Intel Elkhart Lake系列处理器
支持DDR4内存, 最大32GB, 支持TPM 2.0
6*千兆电口, 2*千兆光口, 2组三代Bypass
3 M.2支持SATA, Wifi/BT, 4G/5G
1*HDMI, 1*VGA, 支持双屏异显
规格:
General | |
CPU | Intel® Atom™ X6425RE CPU, 4 cores, up to 1.90 GHz, TDP 12W or Pentium® J6425, Celeron® N6211 |
Memory | DDR4-3200, 2*SO-DIMM, up to 32 GB |
TPM | TPM2.0 Onboard |
Storage | 1*mSATA/ M.2 (Key-M, 2242/2280, SATA SSD) 1*SATA 3.0, 1*EMMC 8/16 GB |
Expansion Interface | 1*PCIe x8/ M.2 (Key-E, 2230, WIFI+BT) 1*M.2 (Key-B, 3042-4G, 3052-5G) 1*EXT-CARD Header (COM5-6TTL+I2C+eSPI+2*USB2.0) |
BIOS | AMI UEFI BIOS |
System | Windows10, Linux |
I/O Interface | |
Ethernet | 5*Intel® 1Gbps Ethernet Controller, RJ45 1*Marvell® 1Gbps Ethernet Controller, RJ45 Support 2*Gen3 Lan Programable Bypass 2*Marvell® 1Gbps Ethernet Controller, SPF |
Serial | 4*RS232, 2*TTL (in EXT-CARD Header) |
USB | 1*USB3.0, 7*USB 2.0 |
PS/2 | 1*PS/2 Header (Keyboard & Mouse) |
GPIO | 8*Programmable GPIO |
Display | |
Display Interface | 1*VGA: max resolution up to 1920*1080@60Hz 1*HDMI: max resolution up to1920*1080@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | 203*182mm |
Power Input | DC12V |
Temperature | Operation: 0℃~60℃, Storage: -20℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
信步自动化核心模块载板SV-B9689
信步机器人控制器核心模块载板SV-B1000
信步新一代高可靠工业计算机NAV-700
“一花独放不是春,百花齐放春满园” —— 信步科技展会侧记
把机器变成人,2023 信步开门红!
