![](http://nfs.gongkong.com/Upload/trade/201512/20151221142253547_w.jpg)
- 型号: Bently Nevada 3300/20-01-05-02-00
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Bently Nevada Dual Vibration XY/Gap Monitor 3300/16-03-01-02-00-00-00
Bently Nevada 3300/50-02-01-00-00 Tachometer Monitor
Bently Nevada 3500/25 Keyphasor Module
Bently Nevada Dual Thrust Monitor 3300/20-03-01-02-01-00
Bently Nevada Dual Thrust Monitor 3300/20-02-01-02-01-00
Bently Nevada Dual Vibration XY/Gap Monitor 3300/16-02-01-00-00-00-01
Bently Nevada Dual Vibration XY/Gap Monitor 3300/16-03-01-02-01-00-00
Bently Nevada 3300/20-02-01-00-00 Dual Thrust Monitor 330020 30-0-30 mils 20 mA
Bently Nevada Dual Thrust Monitor 3300/20-03-01-01-00-00 PLC PWA135313-01 82362
Bently Nevada Dual Thrust Monitor 3300/20-03-01-00-00-00 PLC PWA135313-01 82362
Bently Nevada Dual Thrust Monitor 3300/20-05-03-01-00-00 PLC PWA79482-01 82362
Bently Nevada Dual Thrust Monitor 3300/20-05-01-00-00-00 PLC PWA79482-01 82362
Bently Nevada Dual Thrust Monitor 3300/20-01-01-01-00-00 PLC PWA 135313-01 82362
窑炉控制系统必须保证窑炉的温度、压力、液位、燃烧系统的流量等热工参数的稳定.保证燃烧过程中的正常换向。在安全的前提下.控制系统对参数的控制精度是衡量整套系统的一个重要指标.目前有采用PLC控制系统和由单回路控制器冗余控制主要T艺参数。用小型PLC冗余控制换向过程:有使用DCS控制系统.用一台微型PLC冗余控制换向过程。随控制技术的发展,基于PLC的DCS系统目前在国内外都得到了广泛的应用.可编程控制器(PLC)与DCS控制系统的界限区别也越来越模糊。
2温度控制系统
温度控制系统包括熔化池温度控制、工作池温度控制、通道温度控制。因窑炉是一个较大的热T对象.各个地方的温度有很大的差异.无法全部进行测量.只能由工艺人员选择关键点的测量值进行加权平均作为温度过程值(PV),并把这个PV作为被控量改变燃料流量。以维持该平均值的稳定。因此它义包含了燃气控制和助燃空气控制。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Bently Nevada 3300/20-01-05-02-00 Dual Thrust Monitor 330020 25-0-25 mils 20 mA
Bently Nevada Power Supply 3300/12-01-20-00 PLC PWA88219-01 78591-01A Bentley
Bently Nevada 3300/20-XX-XX-03-00-00 Dual Thrust Monitor 330020 75 mils 200 mV
Bently Nevada 83729-01 P 84152-01 XDUCR I/O & Record Terminals 78599-14 PLC
Bently Nevada Eccentricity Monitor 3300/40-03-01-01-00-00 P/N88816-01 PWA82924
Bently Nevada 3300/20 Dual Thrust Monitor 30-0-30 mils 4-20mA PLC Bentley 330020
Bently Nevada 3300/20 Dual Thrust Monitor 4-20mA 30-0-
30 mils PLC 330020 Bentley
Bently Nevada 7200 DECI-R DIFF EXP COMP INP Monitor 72328-19-01-02-02-02-01-15
BENTLY NEVADA 330101-00-40-10-02-05 NSFP 3301010040100205
BENTLY NEVADA 20929-06 USPP 2092906
NEW bently nevada proximitor sensor 3300 5mm/8mm 330100-50-05
Bently Nevada 72132-01 Relay Alarm PLC Bentley 72130-05 72145-01 N 72144-01 H
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
上一篇: Bently Nevada 7200
工控宝APP下载安装
