- 型号:WCS3B-LS221
- 数量:100
- 制造商:深圳市天为机电设备有限公司
WCS3B-LS221倍加福P+F读码器
WCS位置编码系统->读码器
产品特性:
RS485接口;无接触,绝对位置定位;自动监测灰尘堆积程度
规格参数:
最大允许速度:≤ 12.5 m/s
测量范围:max. 314.5 m
编码尺允许安装公差:水平的: 31mm(±15.5mm);
垂直的: 28mm(±14mm)
分辨率:±0.4mm(1,250 positions/m)
工作电压:10...30V DC
接口类型:RS485接口
数据输出码:二进制数据
终端电阻:自带RS485终端电阻
抗干扰,抗冲击,抗振动
认证标准:CSA、CCC认证
工作温度:0...60℃(32...140°F)
储存温度:-40...85℃(-40...185°F)
相对湿度:90%,非冷凝
接线类型:5针M12连接器
防护等级:IP54
读码器:
WCS2B-LS221
WCS3B-LS221
WCS3B-LS246
WCS3B-LS310D
WCS3B-LS311D
WCS2B-LS111
WCS2B-LS121
WCS2B-LS211
WCS2B-LS221H
WCS2B-LS246
WCS2B-LS246H
WCS2B-LS311
WCS3B-LS121
WCS3B-LS211
WCS3B-LS211D
WCS3B-LS211H
WCS3B-LS221D
WCS3B-LS221DS
WCS3B-LS221H
WCS3B-LS221S
WCS3B-LS246D
WCS3B-LS246H
WCS3B-LS257
WCS3B-LS266D
WCS3B-LS310
WCS3B-LS311
WCS3B-LS311H
WCS3B-LS410
WCS3B-LS410D
WCS2B-LS111H
WCS2B-LS121H
WCS2B-LS146
WCS2B-LS211H
WCS2B-LS256
WCS2B-LS257
WCS2B-LS266
WCS2B-LS310
WCS2B-LS311H
WCS3B-LS111
WCS3B-LS116D
WCS3B-LS146
WCS3B-LS147D
WCS3B-LS166D-1
WCS3B-LS211-Y209517
WCS3B-LS211S
WCS3B-LS221DH
WCS3B-LS221HS
WCS3B-LS247D
WCS3B-LS256
WCS3B-LS266
WCS3B-LS267
WCS3B-LS267H
WCS3B-LS310-Y244234
WCS3B-LS310H
WCS3B-LS310H-Y244235
WCS3B-LS310S
WCS3B-LS310SD
WCS3B-LS311 SET
WCS3B-LS311HS
WCS3B-LS311S
WCS3B-LS410H
WCS3B-LS510
WCS3B-LS610
WCS3R-LS246-Y211383
WCS3R-LS24A
WCS3R-LS24AH
WCS3R-LS266-Y211385
WCS3R-LS267-Y214669
WCS3R-LS310-Y211384
WCS2B-LS1**
WCS2B-LS2**
WCS3B-LS1**
WCS3B-LS2**
- 电话:0755-29412192,29412193,13923452066(微信同号)
- 传真:0755- 29179602
- email:sales@sztianwei.net
工控宝APP下载安装
