产品选型
ZVANCOM - OUNTH810FM军工级环网交换机
冗余电源,电信标准通过1.5KV测试100万小时平均无故障-40℃~ 75℃工作环境温度,无风扇
产品分类:
工业以太网 工业交换机 物联网 网络层 以太网交换机 整机 接入传输交换产品
品牌:
Key Feature
Standard Compliance
•  I EEE802.3 10BASE-T
•  IEEE802.3u 100BASE-TX/100BASE-FX
•  IEEE802.3x Flow Control and Back Pressure
•  IEEE802.3ad Port trunk with LACP
•  IEEE802.1d Spanning Tree Protocol
•  IEEE802.1w Rapid Spanning tree
•  IEEE802.1p Class of Service
•  IEEE802.1Q VLAN Tagging
•  IEEE 802.1x User Authentication (Radius)
•  IEEE802.1ab LLDP
•  RFC Standard:
RFC2030 SNTP, RFC 2821 SMTP, RFC 1215 Trap, RFC2233 MIBII, RFC 1157 SNMP MIB, RFC 1493 Bridge MIB, RFC 2674 VLAN MIB, RFC 2665 Ethernet like MIB, RFC 2819 RMON MIB, Private MIB
System Interface/Performance
•  8K MAC address table
•  1Mbits for packet buffer
•  Auto MDI/MDI-X function
•  2Gbps Switch Fabric
•  System log: 1000 records
•  Packet throughput ability: 2.976Mpps at 64bytes
•  Support X-ring function
•  Store-and-Forward switching architecture
•  Wide-Range redundant power design
•  SNMP/Web/Telnet/CLI/Menu Driven management
•  Local configuration: RJ-45 for RS-232 series
•  Port Statistics
•  Port Configuration: Port Enable/Disable, Auto-Negotiation and Force speed, Full-duplex or Half-duplex mode
•  Broadcast/Multi-cast/Unknown Broadcast storm packet filter
•  Firmware update by TFTP
•  Flow Control for Full-duplex and Back Pressure for Half-duplex
•  IGMP snooping
- v1, v2
-Supports 256 multicast groups and IGMP query
•  VLAN: Support Port based VLAN/Tag VLAN(256 entries)/VLAN ID(Up to 4K)/GVRP(256 Groups)/ Double Tag VLAN/ Private VLAN
•  LACP Port Trunk: 4 Trunk groups/Maximum 4 trunk members
•  Port mirror: TX, RX, TX & RX
•  Rate Limiting: Ingress rate limiting, Egress rate shaping
•  Port Security: Static MAC address, MAC address filter, DUMP MAC Address
•  Class of Service: per port 4 queues
•  Quality of Service: Port based/Tag based, IPv4 ToS, IPv4 Different Service
•  SNMP IP address security (10 Sections)
•  SNMP Trap
•  Login Security: Support 802.1x / RADIUS
-Reject
-Accept
-Authorize
-Disable
•  System configure and show: System name, System location, IP address, Gateway, Subnet Mask, DNS
•  Show system information: System firmware version, System command lin e interface, System MAC address
•  SNTP client
•  SMTP supported (6 mail accounts)
•  DHCP Client/DHCP Server/DHCP Relay
•  Configuration Save
•  Alarm Relay current carry ability (1A at DC24V)
Benefits
VLAN for Performance & Security
•  The static VLAN groups up to 256, the VLAN ID can be assigned from 1 to 4096.
MAC IP Security
•  It supports ingress and egress MAC address filter and static source MAC address lock, Dumping MAC address Table.
•  Support 100 MAC address for Static MAC address, MAC address filter, DUMP MAC Address in total of 8K.
IP Security
•  Support 10 IP address accounts for system management security for Web, SNMP and Telnet management security to prevent intruder.
SuperX-ring
•  Provide SuperX-ring, Dual Homing, and Couple Ring.
•  Provide redundant backup feature and the recovery time below 300ms.
Port Trunk for Bandwidth Aggregation
•  802.3ad with LACP function. Up to 4 trunk groups and maximum group member up to 4 ports.
Port Mirroring
•  Global system supports 3 mirroring types: “RX, TX and Both packet”. The maximum of port mirror entries is up to 8.
SNMP Trap
•  Cold start, link down, link up, authorization fail, SuperX-ring topology Change, Power status, Trap station up to 3.
Redundant Power
•  Support Redundant Power DC 24-48V.
LED Deion
Per unit: Power (Green), Power 1 (Green), Power 2 (Green), Fault (Yellow), Master (Green)
8 port 10/100: Link/Activity (Green), Full duplex/Collision (Yellow)
Fiber: Link/Activity (Green)
Hardware Spec.
Feature  Detailed Deion
•  ROM
•  RAM
•  Power supply
•  Power Consumption
•  Operating Temp.
•  Operating Humidity
•  Storage Temp.
•  Fan No.
•  Case Dimension
•  Mounting
•  EMI
•  Safety
•  Stability testing
4Mbytes
32Mbytes
DC 24-48V
9.54 Watts
0℃ to 60℃
5% to 95% (Non-condensing)
-40℃ to 85℃
N/A
IP-31, 72(W)x105(D)x152(H)mm
DIN Rail, Wall Mount
CE, FCC A, EN6100-4-2, EN6100-4-3, EN6100-4-4, EN6100-4-5, EN6100-4-6
UL ,cUL, CE/EN60950-1
IEC60068-2-32 (Free fall), IEC60068-2-27 (shock), IEC60068-2-6 (Vibration)
Order Information
Product Name
Deion
OUNTH-810FM 8 10/100TX plus 2 100FX (SC), w/SuperX-ring managed industrial switch, multi-mode fiber, 2Km
OUNTH-810FM-15 8 10/100TX plus 2 100FX (SC), w/SuperX-ring managed industrial switch, single-mode fiber, 15Km
OUNTH-810FM-30 8 10/100TX plus 2 100FX (SC), w/SuperX-ring managed industrial switch, single-mode fiber, 30Km
OUNTH-810FME 8 10/100TX plus 2 100FX (SC), w/SuperX-Ring and Wide Range Temperature(-40℃ to 75℃) managed industrial switch, multi-mode fiber, 2Km
OUNTH-810FME-15 8 10/100TX plus 2 100FX (SC), w/SuperX-Ring and Wide Range Temperature(-40℃ to 75℃) managed industrial switch, single-mode fiber, 15Km
OUNTH-810FME-30 8 10/100TX plus 2 100FX (SC), w/SuperX-Ring and Wide Range Temperature(-40℃ to 75℃) managed industrial switch, single-mode fiber, 30Km
ZVANCOM - Carat6508高性能冗余环网交换机
ZVANCOM Carat4000M插卡式全网管千兆交换机
ZVANCOM Carat20PoE 以太网供电全网管工业交换机
ZVANCOM Carat20-S可网管型工业级以太网交换机
ZVANCOM Carat10A工业以太网交换机
